C28 potable water pump access
Calypso
R-21 EC
Where is the potable water pump in a C28 and what is the easiest way to access it?
It is located down in the cave, starboard side. You can peel back a panel held in place with Velcro to get a look at it, but to access it you’ll need to roll back the mattress and remove a few screws from the wall.
Hi Calypso,
You should be able to find the pump right ahead of the forward wall in the quarter berth, under the helm. If you look (feel?) around the forward wall, you will notice there are several screws holding the forward wall panel in. Simply remove those screws and remove the panel. You will see the pump on the floor ahead of that wall, along with the hose from the toilet and the check valve, etc. Hope this helps.
Cheers,
Ralf
