C28 Stern Thruster - Replacing Shear Pin
shieldsfx
Cutwater 28
Dona Sea
How do you access the C28 Stern Thruster to replace the shear pin? I've done the Bow Thruster change, but first time for Stern. I understand it's a bit more difficult?
As an update: I've spoken to Ronnie who guided me on how to access the stern thruster. It's basically under the swing bench. Here's how:
1. Remove bottom cushion on swing bench, removing three screws
2. Remove the two larger bolts holding bench to boat. One is accessible on both sides, but the other requires you to remove the cupholder to access.
3. Remove 4 screws holding lid (the flat top under the swing bench)
4. Remove 4 screws holding tub, remove tub.
5. Remove 4 screws from front small panel in front of tub (this will allow better reach when removing thruster)
Stern Thruster should be visible on bottom right. The exhaust hose is in the way but can be moved or removed for better access. There's another scupper hose which can also be removed (I noticed mine actually had a slit/leak, so I replaced).
Now for the fun, removing the two bolts holding the thruster. I was able to get one off with 6mm hex wrench, but could not remove the right one, due to torque. I understand there's a special tool, which Ronnie is sending, so not fixed yet. We'll see and report back, but definitely harder than changing the bow thruster.
I have not had a shear pin break yet but would like to be prepared in the event I do . I have a 26 Cutwater and would think it is the same or very similar to remove the motor bow and stern . I got down to each one to see what size wrench I needed and found that fabricating a tool would help in the removal of the socket head screws . I wasn't sure of the wrench size because my allen wrench was to big . 6mm is the right size ? I was going to take a small ratcheting wrench cut a allen to shorten it enough to fit and tack weld it to the wrench. If cutwater has a tool better yet !
Brian Brown
PORT A GEE
26 Cutwater
