C28 zinc
Tardis
Cutwater 28
Tardis
The manual shows a prop zinc at the prop location, but I don't see one.
The only zinc I see is the large diver zinc on the back. Can you list the location and type of any other zincs that might be onboard.
there is a zinc on each of the thrusters on the torpedo end. there is a zinc on he end of the prop shaft that is secured to the prop nut. the transom zinc, there are also 2 zincs on the Volvo one on each side of the heat exchanger,
if any questions please feel free to call me
Ronnie Gonzales
Ranger Tugs \ Cutwater customer service
ronniegonzales@cutwaterboats.com
425-220-3932
I also have the same question on the zinc repalcement
boat zincs .com said they dont know and Cutwater dealer or factory should have a list.
Dealers dont have a list and said to call factory.
Location and diagram of ALL zincs on the C28 w/ yanmar
where can i get a transom zinc?where does it go?
any pictures of factory mounted transom zinc and model number?
THANK YOU
Large transom zinc on new C-28's between prop and right trim tab...just under the swim platform strut.
Image posting problem so cannot post the picture.
Variable installation of trim tab zincs....mine did not have any initially. Cutwater installed later.
Later, Wayne
Older C 28's do not seem to have the trim tab and transom zincs. I too would like to rectify that and get pics and mounting instructions!
Picture on YachtWorld shows the C-28 large transom zinc between prop and tab on the starboard side.
Pics also show trim tab and rudder zincs installed.
Our C-28 from Spring of 2014 did not and does not have a transom zinc.
Our rudder did not and does not have a rudder zinc.
http://www.yachtworld.com/boats/2014/Cu ... PSi1ZNExHk
It seems there's no full list of Zincs/Anodes for the Cutwater 28. I thought I would use this post to list them...
Prop (1)
Trim Tabs (2); not put on earlier Cutwater models
Thrusters (2)
Engine (2); on either side of heat exchanger
Transome (1); not put on earlier Cutwater models
Mase Generator (1); to the left of the sea water inlet
TOTAL: 9
Pretty sure I got'm all
