serpa4
- Jun 20, 2020
- R-23 (Sterndrive)
- FMLC3051D818
- DayLo
Got my Xantrex 3000watt inverter with 150amp charger installed (lithium coming later).
Got my 2 x 435 watt solar installed with a Victron 150/70 controller. Should mathmatically see 60amps on perfect day.
Installed a Induction cooktop and wired to inverter and not the generator. Didn't like running generator to cook simple meals.
Installed new tires 225/75/15 Load Range G, 3500 lbs tires on 6 new rims rated for higher pressure. Had two tires separate the belts this year 2021. New ones are 14 ply.
New brakes all the way around.
Kicker motor mount for a 20hp EFI motor. I plan to hit the Bahamas, so want a backup engine.
Bennet Drop Fins installed. Cannot wait to test them.
Vesper Marine AIS with remote anchor drag alarm and button under bedroom AC control.
Wife wanted the Euro counter tops gone. This left screw holes, so I put up some back splash stuff.
Installed new (under warranty, thanks Garmin) autopilot GHP10 installed. Decided to protect the new pump and installed the check valve kit also.
Mantus 35lb anchor.
PUrchased a new tender, 8.9ft with air floor.
Tohatsu EFI 4-stroke outboard.
Victron BMV 712 battery monitor installed.
Hope to hit lake Powel this next month and test all my systems and de-winterize.
Mantus 35lb anchor.
