Markl
- Nov 27, 2016
- C-26
- FMLR2506F011
- No name yet... Coming soon
Cabin door latch is too low to latch on to the keeper when wide open. This is on a 2011 25 foot Ranger. When I first got the boat last spring the door worked good. After a month or two it was getting hard to close so I checked the hinge screws and whatnot. Ended up shaving down the little plastic piece on the bottom of the frame to get the door to close. Then had to loosen the screws on the frame latch, push down and retighten to get the door to latch closed.
Now my big problem is that the door is too low to engage the latch that holds it wide open but it is not off enough to let me remove the latch on the door and re-drill. The problem seems worse now than when I put the boat away last fall. There does not seem to be any play in the hinges and I can't see any sign of the door frame itself moving.
Any idea's how to fix this are welcome. HAs anyone else had similar problems.
Mark
Mark
