If you removed the heater hoses and no water was coming out then how would you be able to bleed them. I just bought a new R-27 and I am not very familiar yet with the systems, but logic tells me that there must be either a thermostat or a manual lever to open a valve to allow the hot water to get into the core. Check to see if the valve is operating. Also, I would think a call to your dealer should give you a good heads up as what to do. I will also look through all my manuals, I seem to remember there is a manual on the heater. If I find anything I will let you know.
