I have the 21 with Volvo. D1-30F 869645 5102161261Y
I took out the factory AC (it didn't work well) and put in a 120v AC with an inverter. The AC is fine, the inverter works perfectly. The challenge is that at idle and very low speeds the alternator can not keep up with the load so the batteries drain. The alternator has way more than enough capacity at slightly higher engine speed. I'm thinking that a slightly smaller pulley on the alternator will cause it to turn faster at lower engine speeds and then everything will be perfect. Advice, please. Is there a smaller pulley available? source? If you don't know a source can you tell me the make and model of the alternator, please? If smaller pulley on alternator is not available, how about a larger pulley on the engine? In south Florida the AC is a must and I need to get it to work at lower engine speeds. "fat people sweat a lot" I need help!
