Canvass cleaning refreshing
CaptnRanger
FMLT2723H122
SWEET RETREAT
Anybody have a good way to remove mold and mildew from under cockpit canvass. Tried soap and water brushing doesn’t do much.
Oxyclean. Soak. Rinse
Thanks will try it
Tried oxyclean no help will try star brite mold cleaner.
I remove the canvas, lay it out and pressure wash it - which removes the grime etc. Then I fresh coat it with water proofing spray. Does a good job of removing the mold and mildew.
Jeff
Power spraying was going to be last resort.. I used Starbrite mildew stain remover scrubbed it with a brush. Let it sit for 20minutes rinsed it off and it worked great. After it dries, I’ll spray it with 303 aerospace protection.
Jeff
Sounds a lot faster than pressure washing - might try that this coming Spring. Thanks for the heads up.
I just cleaned my cockpit canvas (Sunbrella). Parts of it had black mold, other parts where rain water stood for a while had green moss and still other parts were just dirty. I took it up to the laundromat and washed it with 2 cups Arm & Hammer Detergent and 2 cups Clorox bleach. 95% of stains came out with nearly a fully recovered fresh appearance. The canvas fully dried back on the cockpit frame. Did not put in a dryer.
Thanks for the info - where are you located?
my experience:
scrub
machine washing machine if it will fit
starbrite products including mold remover.
rewaterproof spray
