CORPSVET
- Aug 12, 2013
- C-24 C
- Non-Fluid Motion Model
- Cutwater 28
- CorpsVet
I just had the left rear brake on my 2013 EZ Loader trailer lock up. The problem is too long of a hydraulic brake line to an axle, this allows a KINK to form which restricts the return of fluid after applying the brakes. The brake locks up and movement is difficult and can cause damage. A hot brake is least of the problems. In my case, my F-350 7.3ltr diesel 4x4 pulled the trailer (yes I thought it was working too hard and planned to take my truck to the shop to find out why!). Thankfully, I only had to go 4 miles and at less than 50 mph. I did my inspections before/after loading my 28 Cutwater. Trust me a kinked brake line/locked up disk brake is not that easy to detect. The brake caliper mounting plate ripped all 4/5 bolts from the axle, this dropped the caliper/axle down on inside of tire/wheel rim. It was on post inspection on returning home..did I mention ONLY 4 miles!..that I noticed the left rear rim/tire too hot to touch! At this time I guessed I had a locked up brake, so I called Woodenville EZ Loader and they mentioned a possible KINKED brake, while they were on the phone I crawled under trailer and found above damage! Scott (trailer Tech) said he would come immediatley< I TOLD HIM TO WAIT TILL NEXT DAY, I live in Oak Harbor on Whidbey Is.,it was already afternoon). They were at my house early AM , REBUILT ALL 4 AXLES/BRAKES, REPLACED TIRE & RIM ..OOHRAH!!! These guys are GREAT! If you have ANY trailer problems call them. If your trailer suddenly becomes EXTRA hard to pull or a wheel stays/repeatedly locks up.. Check for kinked brake lines!! These are triple wall lines..you may have to flex/feel lines by hand to detect kink.
