stwendl
- Aug 11, 2015
- C-28
- FMLT2719J516
- Cataleya
Just wanted to share this info.
My 2016 r27 has 2 sets of ceiling lamps in the main cabin, one called chart light which are red LEDs, on a set of white halogen lamps in a different flat bezel type recessed holder.
To access the halogen lamps use a small screwdriver or knife tip to gently pry out the smaller ring surrounding the glas. Do pry out the outer ring at the ceiling backdrop. Make sure to capture the ring and glass as it may suddenly pop out when the spring clips decide to do so. There is not need to twist or push and turn. Of course your installed model may be different.
Took me some time to figure out with the help of some friendly Rangers. Learned something new at the rendezvous
