TBates":eoowaoa6 said:
Hi tantytpt,
The Volvo impellers are due to be changed every 24 months or every 400 hours (whichever comes first). Please feel free to reach out with any other questions we can help with.
Thank you,
-Tim
The 2016/2017 owners manual for the Volvo Penta D3 models
Every 100-200 hours / at least every 12 months
Engine Oil and Oil Filter
R
Crankcase ventilation filter
R
:Every 200 hours / at Least Every 12th Month. I= inspect R= Replace L = lubricate
Coolant level and antifreeze mixture
I
Air Filter
R
Fuel pre-filter and fuel fine filter
R
Seawater filter
I
Drive belt (tension)
I
Impeller, raw water pump
I
Reverse gear, oil and filter
R
Reverse gear, propeller shaft seal
I
Outboard drive, oil
R
Outboard drive, corrosion protection
R
Outboard drive, propeller shaft. Visuall inspection of propeller seal.
IL
Outboard drive, U-joint and primary bearing
L
Outboard drive, bellows, rubber hoses and clamps
I
Checking exhaust line
I
Outboard drive, universal joint bellow
I
Hydraulic hoses and fittings. Thoroughly inspect for signs of leaks, wear, cracs or aging
I
Engine and transmission, oil / fuel / water leakage
I
Engine and transmission, touch up paint as required
L
Batteries, electrolyte level
Every 200 hours or second year
Impeller, Seawater Pump
R
R
Coolant
R
My list in previous post above did not include cleaning the reverse gear cooler. This is easily done by removing the raw water hose and inspecting and cleaning the debris that has passed through the Marine Hardware Sea strainer. The screen is course and seaweed easily passes through the strainer plugging up the reverse gear cooler. This will cause elevated operating temperatures and could reduce the impeller life expectancy. I do not change the yellow antifreeze change on the yearly service. I changed the yellow antifreeze every 2 years. I do not change it at 200 hours. I don't think the engine hours is as important to degrading the antifreeze as the marine life Years is. I changed the antifreeze every other year during my yearly service.
I agree with Britt the engine hours are not as important as the marine life ( Time ) When it comes to the impeller operating that small diameter impeller for 400 hours is a stretch. It would probably make 400 hours if always operated in clean water with no silt, sand, mud and a raw water system frequently flushed with fresh water. The installation in the Cutwaters and Rangers with D3 engines has a limited water flow capacity with the 1" through hull add a marginal impeller into the equation will probably compromise the raw water cooling system.
