R RichardK Well-known member Joined May 21, 2018 Messages 74 Fluid Motion Model C-30 CB Hull Identification Number FMLT2914H819 Vessel Name MY TWO LOVES MMSI Number 338339964 Apr 24, 2021 #1 I changed the once before but can’t remember how I did it. How do you remove and replace the wiper blades. Richard
K Kevin Lamont Factory Employee Joined May 4, 2017 Messages 538 Fluid Motion Model C-24 C Apr 26, 2021 #2 RichardK":2c4ev8nu said: I changed the once before but can’t remember how I did it. How do you remove and replace the wiper blades. Richard Click to expand... Hello Richard, To remove the wiper blades there should be a tab on the plastic hanger, once released it should slide off and then you would reverse the procedure for install. You can purchase replacements from parts@rangertugs.com. Hope this helps. Thanks,
