Charging a Torqeedo on board
jagizzi
C-242 C
R-23, July 3rd delivery, yippee
Next Ten
We are in the process of deciding on a dinghy motor and one of the considerations is whether or not the Torqeedo can be charged on board the boat. I would guess it would have to happen while underway so as not to strain the battery string but am wondering about the practical implications.
Is anyone doing this and if so, how? Can you charge in a couple of hours of cruising? Can you do it through the 12V plugs for the downrigger pads?
Trying to keep the Admiral happy with no gas fumes but not really wanting to deal with refilling and storing propane.
Jim
Yes, it can be charged with a 12v auto type socket or a 120v AC inverter; but it takes more than a couple of hours.
I am thinking of getting a second battery.
I spent a lot of time on this problem.
I netted out to:
1. torqueedo is a good bit of kit but charging times and price just make it non viable
2. propane outboards are a great idea but the current crop are really badly made with lots of failures and getting warranty claims is not easy. - not worth the hassle
3. the new small 4 stroke outboards are light and quiet - especially the suzuki 2.5hp water cooled. if you dont want to refill gasoline in the dinghy then get a separate tank with feeder hose you plug in. pretty much all 4hp and above have these. you probably wont refill all season!
I have used a Torqeedo electric outboard for about a year now on my Ranger Tug 25SC. I chose it because of three parts come in weight that I can handle--I'm a senior sailor. I have changed the battery with the 12 V methods and then with the 12 AC plug. While it takes time to recharge I haven't had a problem with it.
The only problem I've had with this outboard is that I broke the shear pin and had to have help replacing it.
Les
