Thank you, Brian.
I see that this diagram has a 2018 rev date; probably similar to how they configured the older boats, but I'm sure they have updated a few means and methods since 2011. For instance, our boat did not have a main disconnect at the shore power entrance, which is located on the starboard side just forward of the helm side door; nor did it have an ELCI breaker. The ELCI code requirement was just working its way into the mainstream at that point and FM must not have been on board. 120-volt power was led straight from the back side of the shore power plug assembly all the way back to the 120-volt panel and main breaker just inside our main cabin door. I since have added an ELCI breaker and galvanic isolator, but unfortunately there was no practical way to keep those devices within 10 feet of the shore power connection - probably not a lot more than 10 feet though.
The factory did such a nice, detailed job on the 12-volt diagrams on the early 29's - I have only found a few discrepancies on my boat - it's too bad they did not also do a 120v diagram. If nobody else has an older diagram, I'll just do a little research and create my own using the one you forwarded as a starting point.
