Cleaning hull in indoor storage
Marnis
C-302 SC
Sonny Side Up
What is the best method to clean the exterior hull when you do not have water access. My RT 31 is stored indoors with heat. The hull was power washed when it was pulled out of the water but it could use a wipe down. What product would clean without leaving a haze or film.
My detail guy is using a product called "Booyah" all purpose boat cleaner. The best he has found. Google it.
I use vinegar and water on the hull before waxing or bottom painting and it has worked well without leaving any trace.
I use vinegar and water and wipe dry. The vinegar takes hard water spots off and removes old wax, a great method if you’re going to re wax to be ready for the spring.
Jim
I third the suggestion of vinegar and water, Removes water spots, from fiberglass, windows, and stainless. I always wipe the boat down with Vinegar and water before waxing.
