Cleaning the fuzzy white wall covering.
Baetz
C-288 C
T2908F112
Footloose
Does anyone know a good way to clean the fuzzy, carpet like material on the walls of a 2012 R29?
Our R29 has a fuzzy, carpet like material on the walls. We have tried to clean it with soap and water, carpet cleaner, a number of other solutions. All make some impact, none really clean the material so it becomes its original white. In some places it even looks grey.
Does anyone have a cleaning secret?
I've had good luck with a mild solution of bleach and water, spray it on, light scrub and wet vac off.
Lots of you tube videos, look up cleaning monkey fur on boat.
If you go this rout be sure to protect from over spray. Good luck! Bob
We used hydrogen peroxide on the monkey fur with reasonable success. Sponge it on, wait a minute or two then towel dry with minimal rubbing.
I also replaced a bunch of it where located on small panels (eg v-berth ceiling) with foam backed perforated vinyl headliner.
Baetz,
We had great luck with a product called Folex Carpet Cleaner. Spray on, let sit and then dab it out.
