SlackwaterJack
- Aug 15, 2009
- C-24 C (Sterndrive)
- Slackwater Jack (2005)
Hi,
I'm starting the cleanup of my new (to me) R-21 and I have a few questions;
1--Are the portholes for the V-berth solid bronze or plated? mine need a major polishing but will I go through the plating ? are replacement screens available?
2--Any product recommendations to restore the colored gelcoat? the sides are real nice but the "visor" is a bit faded.
3--Has anyone shortened the mast? (by about 2 feet). If so, how? lessons learned? able to retain the "boom"? It seems to me that the easiest way would be to just remove the "topper" and about 4-6'' of the mast below it. That would retain all the original rig geometry. I would need to fabricate a new "cap". I'd like to retain the mast, but there is 1 bridge that I need to go under that varies from 10 to 16 ft of clearance, depending on River level. It does lift but there is never anyone to raise it unless you make arraingments a couple weeks ahead of time.
As an off-season project...
Has anyone thought about or actually relocated the batteries and/or fuel tank into the rear storage seat? Is there room under the floor to run new longer fuel lines and longer (heavier guage) battery cables? I'd really like to be able to check the packing gland, bilge, and pump without a tool kit and all the hassle.
All comments appreciated.
