nzfisher":2dh6i99o said:
I don't close my raw water valve except when cleaning metal grate.. My boat is never in a place where water could freeze. I am wondering why people close it with the risk of forgetting to open it each time you go out is so high. My notion is that if the hoses fail I would rather it sink in the birth than at sea. I am sure that there are other opinions and I would like to hear them just to be sure I am not missing something- thanks.
Hello NZ,
I don't mean to be argumentative, but I think there is 'another' way to think about this...
You create a false dichotomy by saying "if the hoses fail I would rather it sink in the birth than at sea." Certainly no one wants their boat to sink. And I know you didn't mean it that way. There is NO REASON the boat needs to sink...anywhere (at the birth, at sea, etc). The "other" option as pointed out above is to NEVER leave seacocks open on an UNATTENDED boat. If a hose 'fails' whilst you are 'away' - and the seacocks are closed...NO PROBLEM! Likewise, if a hose fails whilst underway, you will detect the failure BEFORE the boat sinks and close the seacock. Again, your boat is 'saved' whether at the birth or underway since, if any seacocks are open, YOU are aboard.
If you analyze the origin of boat 'fires' you will find that the VAST majority are 'electrical' in nature. Thus, the advise to TURN OFF everything possible is good advise. ABYC standards dictate the bilge pump/s be wired DIRECTLY the batteries, so they WILL FUNCTION even with the battery switches off. Chargers usually have leads going DIRECTLY to the battery terminals, so, again, they continue to do their duty with battery switches OFF.
The questions asked such as "But will my bilge pump work if the battery switches are off?" is an EXCELLENT question. It has been answered on this forum MANY times...however, this means that YOU HAVE NEVER INVESTIGATED YOUR OWN BOAT! YIKES! Some level of "self rescue" is REQUIRED if you go out in a boat which means, in this case, you must know WHERE THE BILGE PUMP FUSES ARE LOCATED. Since they are wired directly to the battery (WHICH BATTERY...on YOUR boat?) there will be a fuse very near the battery...ABYC requires it be within 7 inches. When that fuse blows, the 'auto' function on the bilge pump is lost. So, you should know WHERE it is...and have SPARES aboard.
You've read about the hose clamp coming loose and the pump emptying the Fresh water tank into the cabinet or wherever the hose separation occurred...again, if the battery switch is OFF (or the pump OFF at a minimum) when the owners left the boat then the mess wouldn't be nearly as big. The alternative scenario is that it WILL HAPPEN but you will be there and stop it before all 40 gallons of FW empty onto your provisions. You see, we are back to the seacock question...have them open ONLY when the BOAT IS ATTENDED. (i.e., switches, like seacocks, should be open/on only when the boat is attended)
Sorry for the rant. This is not meant to be personal in ANY WAY and I meant no offense to anyone. I am still learning too...
dave
