CO monitor alarm is super sensitive—help!
Blueboy#1
The CO monitor alarm in my boat seems overly sensitive. It sounds when I am taking fuel and the Yamaha F300 engine has been off for a minute or two.
In addition the alarm sounds (loud and distractingly obnoxious) when the boat is leaving the dock or taxiing slowly around the harbor—even with the door to the afterdeck and all hatches and windows closed. It sounds continuously for minutes on end not stopping unless I speed up and open all hatches, and even then it sounds for a long several minutes. This makes slow boating really aggravating especially when near wildlife.
Does anyone else experience this problem? Any suggestions for a better solution than running fast to clear the air?
It could be you have a bad CO2 monitor. I would verify that you don't have a propane leak as well with a gas sensor.
Use a sensor like this:
