command bridge seat move
fishingdad
FMLC3042B616
As a new owner of a 2016 30CB so far I have found only one thing I really want to change. Has anyone moved the bench seat back from the dash to get more seating room? I thought maybe there would be an adjustment but didn't find anything there. Other than this one item so far the boat has been great, and as soon as WA opens back up fishing will be back out there again
On our C30 there is an adjustment lever just left of centre on the forward side of the seat. Ours has a small black hard plastic end on the lever - maybe this end came off or the lever itself is not there? We move our seat frequently to get more or less room at the helm area and also we need to move the seat forward so that we can convert it into the table bench seat. I am assuming that you are referring to the lower helm seat.
If you are talking about the most forward seat on the bridge of a command bridge with the hardtop and 3 rows of seats, the seat slide back and forth. Also, as I did, you can unscrew it underneath and move the seat forward or back on the mount brackets as you with. Easy to do.
Bobby
