I recently installed the Garmin rudder angle indicator on our 2019 R31. Because our set up doesn’t have the Smartpump, the installation was NOT plug and play. With the Smartpump, as I understand it, the plug on the end of the sensor simply plugs into the Smartpump and you’re good to go.
Instead, I had to also buy a cable (Garmin GRA 10) that converts the signal from the angle indicator into a digital format. That cable then gets plugged into the NMEA backbone. To make it work, you have to connect the rudder angle indicator cable, which has a plug on the end, to the GRA 10 cable, which has loose wire ends rather than a plug.
To make connect the two cables, I followed the advice from this thread:
http://www.tugnuts.com/viewtopic.php?f=24&t=8656&p=60318&hilit=GRF+10#p60318. Basically, I cut off the unneeded plug from the cable coming from the rudder sensor and connected the wires from that cable to the extension cable. The key was to connect only four of the wires (red, yellow, black and a bare “drain” wire) and ignore the others. The Garmin instructions were less than helpful on that point. I had a lot more cable than I needed, so I cut off some of the excess, while leaving myself enough to have plenty to work with plus some slack.
Once I cut the plug off the rudder angle cable and figured out the right attachments to the GRA 10 cable, the rest was easy. Well, easy in terms of making the electronic connections. I made crimped connections between the four wires (red, yellow, black and bare), which is a bit challenging because the wires are so fine (24 gauge, I’d estimate). But it can be done. Once done, the other end of the GRA 10 cable then attached to the NMEA backbone, and the Garmin NMEA network recognized the rudder angle signal immediately. (Note: Figuring out how to attach the rudder sensor itself to the rudder arm and the back stern wall was more challenging. I got that worked out too, and anyone interested in how I did the sensor attachment can feel free to PM me). The downside to the Garmin setup is that the combination of the GRF 10 (sensor) and GRA 10 (adaptor cable) made for an expensive way to add rudder angle information to my helm data, since the second cable cost nearly as much as the sensor itself. But for me, it has proved worth the expense.
