KBHARDER
- Jan 28, 2011
- C-302 C
- FMLT3111GS16
- STARBIRD 2016
Kevin Lamont
I’m getting ready to do a coolant change on a D4-300 and was also considering removing the feed line to the water heater to better purge the system. In your recent D3 reply on the same subject you mentioned a “small forward drain valve” on the D4. Is that drain valve mentioned here in addition to the two drain valves referenced in the maintenance manual located on the port side of the engine OR is it an additional drain valve located at the front of the engine?
Additionally, for anyone that has previously done a coolant change on the D4/6, any firsthand knowledge or advise would be much appreciated.
Since the two drain cocks are located in such a restricted access area, I see most of the coolant discharge ending up in the bilge. How has this been handled? Has anyone considered using an evacuation pump to easily siphon the coolant uphill to a remote collection bucket?
I am familiar with the specific coolant requirements and the procedure to ‘burp’ the system after refill.
Thanks in advance for your help.
Kim Harder
STARBIRD
2016 R31S
Kim Harder
STARBIRD
2016 R31S
