Coolant Drain 2015 R31 (D4-300)
JeffreyAC77
2015 R31-CB (LE)
Lake Union, Washington
R-31 CB
FMLT3106E415
State of Mind
Can anyone direct me to the proper drains to change out my coolant? TIA.
I have found those diagrams - thanks. Are they the only two locations to drain the coolant on the D4-300 (2015). - pictures 1 & 3?
Note of caution. Those drain cocks are plastic and not available. So, be very careful and don't over tighten.
Thanks for the warning. Are there only 2 drain locations to do the whole system on a D4?
Sorry, not versed on the D4, just learned the hard way about the drain cock.
Yes, those are the only two drain cocks on a 2025 D4-300.
Thanks for your confirmation. I have read about needing drain the hot water tank as well - is that true or am i wrong about this?
I believe you are referring to the engine coolant circuit that goes through both the water heater and the helm controlled cabin heater. I believe you will find owners who recommend draining that circuit when doing a coolant change and other owners who do not. There are two valves on the front of the engine that open or close this circuit. When I did my coolant change, I chose to close those valves and only drain the engine block coolant as I was concerned with introducing air into the hot water heater/cabin heater circuit. This meant I was not replacing all the coolant, but since I do this about every three years, I was not concerned with mixing old coolant. Your 2015 D4 probably has Volvo yellow antifreeze in it. I believe that for the last year or two, you can only purchase Volvo orange antifreeze. But the orange antifreeze is advertised as compatible with the older yellow antifreeze. In my previous comment, I mistakenly said 2025, rather than 2015 D4. My boat is also a 2015.
Hey Steve!
About how much is extracted?
Thanks for your answer - it is much appreciated.
Hey Steve!
Hi Steve! I was not dutifully measuring the quantity extracted, but based on memory, I had to put in about 3 gallons to refill the engine coolant. The spec for the engine is 13 liters or 3.4 gallons, so I was getting most of the old coolant out. Not that you asked, but the water heater/cabin heater circuit has approximately 5 liters, which I did not drain out.
That's a big help, Steve! Thanks!
10mm ID tubing. I couldn't find any and I bought 3/8" ID. With some stretching it worked, but 10MM would make it SO much easier in a tight spot. I hooked it up to a drill powered pump and it worked great!
