portlandtug25
- Jun 17, 2014
- C-26
- Regalo
Hello,
As per my posting earlier this month, I'm experiencing very slow leak ( lost about 8 oz after a 9 hour cruise) at the brass elbow on the heater hose right by the oil dipstick. Another D3 owner with the same issue told me that the problem turned out to be a missing washer in the elbow connection in his case. On my boat the hose clamp on the outflow side of the elbow seems tight and not the source of the leak, so I suspect it is the same problem, ( and I've shut both heater hose valves )
So here are my questions:
1.If indeed, in my case also, it is a missing washer, is that something that requires a specific Volvo part and mechanic to fix, or is it a part that any good boat mechanic could replace?
2. If I don't fix it right away, is it likely that it is going to get drastically worse suddenly?
3. Is there a way to block or cut off the coolant flow to this elbow, so that a complete drain of the cooling system isn't necessary to R/R? I've got the valves to the hot water heater and the cabin heater both closed.
3. Why would it not leak at all for the first 240 hours of operation ( the boat has 249 hours on it) and then start leaking?
Thanks! Any help would be appreciated soon since I'm planning an early September cruise.
Roger Friedel in Portland
