Old Master
- May 8, 2009
- C-24 C (Sterndrive)
- Old Master
I have a 2005 R21, 3-cyl 20 HP Yanmar (of course.) Last fall my cooling alarm went on. I cut off the engine for awhile and opened the motor cover. It started okay, so I steamed back to port at dead slow. Took it to a mechanic, who "flushed the system," and changed the impeller, telling me it had a couple of broken blades.
Took it out again, same thing happened. So, filters are clean, system is flushed out, new impeller, but alarm comes on after about ten minutes at dead slow speed. (I turned on the heater, opened the cover, and steamed back to port at dead slow.)
Other than this, the engine runs fine. Also, be advised that this boat has had what would be considered minimum use, professional care, and never ran in "dirty" water (although the Ohio River is not "clean.")
Is it possible I need a new thermostat, or could this be something more ?
And BTW...I can't find anybody in the Cincinnati / Northern Kentucky area to work on my engine. Any referrals?
