Corrosion on base/feet of cockpit table
Webwright
R-29 S
(Photo attached)
I’m trying to clean up a recently purchased 2022 Ranger 29S…. It’s in pretty great shape, but the feet in the cockpit seem pretty seriously corroded…. I’ve seen this on several other late model Rangers. Does anyone know what metal these feet are made of? Can they be brought back to a pretty state? Are they replaceable?
personally I would remove them from the deck as it looks to be pretty simple screws holding them in place ... then clean and then surface prep and paint with a good quality paint matched to material if you can't get the finish you want by just cleaning ... I can't tell what material they are but with proper coating they should survive a log time in the marine environment. They look completely serviceable with no need to replace.
I ended up painting mine. The factory sent me new ones, but they did the same thing. They are holding up well with the paint.
