Cutting Board
Bobby P.
C-302 SC
Boston Whaler
The Retreat
Need to replace the cutting board that covers one of the double sinks in my R31.
Does anyone have a source?
Bobby
Mr. Bobby, I replaced one in my horse trailor/living quarters by buying two at the local hardware store and cutting them (one small to fit inside the sink, one large to fit the top of sink) and glued them together. The white plastic cutting boards are easy to work with with normal wood working tools, the glue I used was 3-M 6000 (I think). Total price of material and glue was about $25.
Hope this helps if you can't find what your looking for. Bob
You can custom order one here: www.cuttingboardcompany.com
I recently purchased a 1/2" thick custom board in white with square cut edges and a juice groove all around. I sent them my measurements, got the board in less than a week fabricated exactly to spec and dropped it in. You may want to also purchase some rubber feet to put on the back side so when you remove it to place on the counter it doesn't trap liquid underneath. Total cost delivered was $67 paid to an American company. HTH, Gary
We also used The Cutting Board Company to make custom stove tops and a table top. We used laminated bamboo which holds up well and looks good with the teak interior. A number of other materials are available. You can very quickly spec your board by thickness, dimension, edge type, corner type, and juice groove (or not). Quick and easy. Great company.
+1 for rubber feet!
Cheers,
Bruce
When I bought my boat used, it did not come with one. I saw a similar boat at a boat show or someplace so I thought I need one of those! I called RT parts dept and they sent one along with some other must haves.
