MsChief":3nuodbi9 said:
Brian
That is very useful info. Thanks for sharing. I’m surprised by your engine temps at cruise rpm. At 3400 rpm my temps are 170 to 180 degrees. And that’s with full coolant tank. I wonder if something is wrong. I also have the Cutwater 26 w D220. I’ll have to ask the factory guys when I get to Roche Harbor next week.
Laura
MsChief Cutwater 26.
The posted temperatures that are referred to in my post are related to engine compartment temperatures 140 degrees F to 150 degrees F. The C26 has a very tight engine installation much different from the other models that use the D3. R25 and R27. The Tugs have a full open compartment for the install. Open the hatch on a 25 or 27 Tug and the engine is exposed in a open compartment. Open the engine hatch on a C26 and this is what you see. Most of the engine is installed under the deck in a very confined area. The area shown in the picture(open area near electronics and reverse gear) stays 20 degrees cooler then the area where the engine air intake is. Maintaining 120 degees F to 130 degrees F with the use of my added compartment exhaust fan and 4" vent installed on the port side. This is marginally expectable to ABYC and VOLVO specs.
The intake areas higher compartment temperatures concern me ( 140F to 150F+ ) because of realized performance issues, and opinions given to me by the local Volvo Dealer, the regional Volvo Rep, the phone technicians at Volvo that the Dealer spoke to, and a Volvo Rep that assists Cruiser Yachts in Volvo engine installations that the dealer I am consulting with, works with. All have stated they have concerns that performance will be effected because of elevated intake temperatures. Fluid Motion technicians disagree and claim the high temps are fine. One positive I have found out from Volvo is the higher compartment temperatures will not effect the longevity of the mechanical components of the engine. The negative aspect is the longevity of electrical components, sensors ,relays, alternator, and common rail electrical components "could be" (opinion) compromised . Exact quote fromTechnical Support - GC
Volvo Penta of the Americas
1300 Volvo Penta Drive
Chesapeake, VA 23320 "If those values are correct, it is out of our recommendation and is not possible to predict what could happen.The engine must work according to our measurements and recommendation." " Engine installation Manual has specs and they need to be followed"
This picture shows the area of concern. The step that is removed is completely layered with insulation for sound deadening. The step coverers the area where the intake and turbo are located. There is heat generated in this area from exhaust manifold and turbo and the only way to dispose of the heat is through the engine.
This picture shows where the highest concentration of heat is . There is no ventilation at all in this area. I have recorded temperatures of 152 F in this area after a 4 hour run at 3400rpm, While running I periodically opening the deck hatch in the pilot house to allow cooler air into the compartment also running the blower.
There are pictures of the ventilation modification that I did last year in my album. I will make more modifications this year to try to get the compartment temperature at Volvos specifications for the D3 and to meet the ABYC specifications.
The temperature that I believe you are talking about is the engine Coolant temperature. At 3400 rpm my engine coolant temperature is right at 180 degrees F + 3 F if sea water temperatures are warmer. If this is what you are referring to Coolant temperature of 170 F to 180 F that should be fine. I would suspect closer to 180F. If you are referring to compartment temperatures at 170 to 180 I would be very concerned and I would ask them about that at Roche Harbor next week.
