Cutwater 28 O/H Fan Port Side not working
bpanerio
R-21 EC
FMLC2809G314
I Think I Can
My Cutwater 28 Port Side O/H fan stopped working. The starboard side works fine. I looked through the diagrams to find a fuse, but no luck. Are they separately connected to power, or if they are connected together, maybe the fan is broke? Thanks for anyone's help!
I would guess they are likely on the same fuse. Bad fan?
Hello,
These are a simple item to diagnose. Remove the fan and disconnect the connector on the bottom side, turn on the fan and check for voltage with a multimeter and that should give you what you're looking for. Also both are tied together so fused together, if one is working and the other is not I would assume you have a bad fan. Hope this helps!!
Thanks for the help!
