abastos
- Feb 16, 2022
- C-30 S
- FMLC3054D818
- Non-Fluid Motion Model
- 2020 Bayliner VR4
- Pas de Deux
Hey folks from Tugnuts,
I'm considering a Cutwater C-30 for PNW cruising. Ideally, I am looking for NW Edition, with Webasto furnace system, but I see couple LE editions available for sale. I understand the LE comes with AC/heat running off the generator. If I happen to buy a LE version, I'm particularly interested in adding a Webasto diesel heater for those quiet anchor nights when running the generator isn't ideal (or neighborly).
Has anyone successfully installed a Webasto system alongside the existing AC/heat setup on their C-30 LE? I'd love to hear about installation challenges, optimal mounting locations, and any potential conflicts with existing systems.
I know FM is moving towards LE only for Outboards, running the AC/Reverse Cycle heating off the LiFePO4 bank. That could be an option too. I could retrofit the house battery bank from lead acid to LiFePO4. With 500-600Ah available and larger inverters, I might be able to run the AC from the battery. Way more expensive, but I think it is doable.
Am I over-indexing the situation? Probably. Appreciate feedbacks and thoughts.
Also, for current C-30 LE owners out there - how's the cabin warmth during winters? Are you finding yourself running the generator often for heat, and how's your experience with the stock heating system?
Thanks in advance for sharing your experiences! I am currently based in Seattle and looking forward to year-round cruising.
Alex Bastos
Alex Bastos
