Teachyspice
- Jul 10, 2020
- R-23 (Outboard)
- FMLC3042C717
- Beula
Good Morning,
I have to trouble shoot my rear thruster. It seemed to labor spin slower with less force for a couple of bursts when I last used it then stopped working. I got down and investigated and the prop was stuck in the tunnel on some salt water marine build up in the tube. I was able to manually turn the prop and clean out the tube.
I checked the main fuse under the battery switches and they were functional. The rear thruster fuse looked slightly discolored but when switched with the bow thruster fuse worked fine. Not sure where to check next. What is likely to fail if the prop gets stuck and won't turn?
Thanks for your time this forum has been a wealth of knowledge.
