D4 Impeller Puller
marob
Viking Rose
Have a new C28 with 130 hours and will be changing the raw water impeller. I have seen pictures of a bolt with a threaded center with a bolt going through to pull the impeller but can not find the thread size for it. Have seen other pullers but not sure if there is enough room to use. Thank you
I never worked on the Volvo, but assuming the impeller is similar to others I just use a large needle nose plier to pull them out. No need to worry about damage because once you are there you may as well replace it even if it looks good. Save it as a spare in the event you need one in a pinch.
