quinsky
- Jul 25, 2017
- R-21 EC
- FMLC2813H
- Compass Rose
I know there have been several posts regarding dinghy davits but I have another question. My C28 has Weaver davits and the boat wake hits the ends of the dinghy at cruising speed. I have the raised davit heads and I moved the yoke pads further outboard on the dinghy so the it sits a little higher. This helped but did not correct the problem. While on a recent cruise the dinghy was bouncing around and I discovered that one of the stand off pads had ripped loose from the dinghy. I was able to secure it and continue. My first question is if it would be feasible to install blocks made of King Star board to raise the davit heads 2-3 inches?
I keep the motor on a mount installed on the transom. I also have a Garhauer lift for the motor. Withe all this and the stand offs it gets rather crowded on the swim platform. Before I raise the heads I want to research installing a traditional lift type system that will hold dinghy and motor horizontally. The Forespar Nova system is one I'm looking at. This system would mount on the swim platform and attach to the stern rail. I'm concerned that the stern rail may not be sturdy enough to support it. Has anyone installed a similar type davit system?
