GZigmont
- Oct 9, 2019
- R-31 CB
- Jack
Have a new to us 2021 R-31 CB with a warranty replaced engine with about 75 total hours on the new engine. I replaced the engine and thruster batteries about three weeks ago with X2 combo batteries from Batteries Plus: Group 31 1150 CCA combo batteries, as the originals would not hold a charge. Batteries have been fully charged and maintained on shore power, except for short outings.
Yesterday we motored to a cove about 15 minutes from our marina on the CT River and picked up a mooring for approximately three hours. Once we were secure on the mooring, I shut off the engine, the ignition and turned off the engine and both thruster battery switches. Although the following would only draw from the house bank, I turned off the inverter, the wine cooler, and the Garmin electronics. The only juice used- and only from the house bank, was for the Fusion stereo, the water pump and toilet.
Upon getting ready to leave the mooring, I turned on the engine and thruster batteries, as well as the Garmin electronics and then hit the ignition switch for the D-4. A brief blip of graphics on the Volvo Penta display, and then it went dead. Start switch was inoperable. I went over the volt meter on the panel, flipped it to engine and it read 0 volts. I paralleled the batteries to get the engine started and it was an incident free 15 minute ride home.
Upon getting to the dock and turning off the engine, the engine battery meter read approximately 13 volts after only the fifteen minute ride. Restarted the engine and it was fine. Turned off the ignition, the engine and thruster batteries. I kept the shore power unhooked for a little while and monitored the engine battery voltage and saw no drop.
Anyone have any ideas? I’m stumped. Full disclosure though, this boat has had some other wiring anomalies on the AC side from the factory. I also found that the automatic side of the aft bilge pup was not working and had blown the fuse. This side of the pump is wired to the engine battery. I tested the pump using another power source and it worked fine. The factory wiring apparently had an actual short, which caused the fuse to blow. I cut the positive at both ends and ran a new clean wire to the pump. The original wire which is part of the harness is not connected to anything at either end, and even if it was shorted to a ground, it’s not connected to anything positive. I don’t think that there is a parasitic current draw from this circuit. I also replaced the solenoid for the propane, which memory tells me is also connected to the engine battery. That system is working properly, so I don’t think there is a current draw on the engine battery from this either.
Finally, I have noticed that the Volvo ignition sporadically turns itself on many times (not all) when the engine battery switch is turned on – similar to how one may set the Garmin electronics. I looked though all of the screens on the Volvo display and read through the manual and couldn’t find such a setting. I’m thinking there is something going on here that might be draining current.
The only thing I can think of doing next is to go through all of the positive leads to the engine battery, one by one and look to see if something is drawing amps even when the battery switch is off. I’m thinking that whatever is going on here is what killed the first battery. What say you?
