Defrost fan
davecook
FMLT2721A313
I have a 2018 R27 LE and I can’t seem to get any fan noise or air blowing when I rock the fan switch on , at the helm . Can anyone shed any light on fan location , ducting , etc . Thanks
Dave, there should be a spade fuse in one of the fuse holders that could be burned out. Some times there are small fuses in the rocker toggle you push to turn the fan on, may need to take that apart to check out.
Jim
Our r27 2020 the fan is under he helm seat. Pull out the microwave and you can see it. Just remove the wood panel the holds the microwave in.
