When we took delivery of our 26 Cutwater we had the same problem. It worked good on delivery while running on the river. We then went for a cruise on the lake (Michigan) 2' waves and it started acting erratic. I found that some some of the propylene glycol had liked out. I lifted the transducer off, got some more fluid,toppped it off, worked great! Until the next choppy day on the lake. Two things were wrong 1) There wasn't an o-ring installed on the housing to seal the fluid from leaking out.2) There are two tabs on the lid that is attached to the transducer one was broken off. The broken tab is not that obvious unless you are looking for it. Being the boat was new I wasn't looking for it and assumed the missing o-ring was the culprit. When I installed it (push down and turn the lid to lock it) the lid seemed secure and locked. It would come loose again ,and with further inspection found a tab (small tab) was broke off. Richard from Ranger parts assisting me with retaining the new lid and no problems since.
Brian Brown
Cutwater26
PORT-A-GEE
