stwendl
- Aug 11, 2015
- C-28
- FMLT2719J516
- Cataleya
So I tackled the issue of loosing fluid in the depth sounder cup and removed the existing cup that was attached with what appears to be 4200. The caulking came off with ease and no effort and apparently little bonding to the cup and hull.
Airmar suggests to use silicone to affix the cup and alcohol to clean the surfaces. Will try this and see how well it holds.
Alcohol cleaning is not recommended with 4200, and acetone may damage the cup plastics. I considered epoxy but that seems to be a too permanent solution in case I need to make changes.
