Diesel heater
Irish Mist
C-288 C
FMLT2922K011
Hi everyone I finially got my diesel heater installed Thank you to all who supplied photos and answers to my questions Hardest part was getting nerve up to drill large holes through boat 🙂 It took me a few days with the ducting being the most work. It is hard to believe the amount of heat something the size of a loaf of bread puts out Is getting cold up here at night and this will make being on the hook a lot nicer🙂
To all the fellow Canadian tuggers have a happy Thanksgiving 🙂
You will love that heater - we have spent many a snug and warm night on the west coast in the pouring rain mid-winter asking ourselves "what in the world are the higher heat settings for?" Enjoy!
I'm looking to install one too on our R29. Which one did you install? Are you going to post some pictures of your install? We are on the west coast and there are many boating days a heater would be nice!
Thanks, Leon
Wabasto gets two thumbs up from us! Just four batteries plus solar panel and no issues keeping up with the heater plus fridge and lights. This was a factory install however.
I suggest that a few minutes before you shutdown the heater set the heat control to the highest setting. I was told by a Wabasto rep that this will inhibit coke buildup in the burner.
Good tip - thanks. It does make sense to have a few minutes at max output; I will add this to the list of myriad little helpful hints from forum users!
The heater I purchased is a Plannar. The distributor is on the west coast and I found him very helpful The heater is Russian made and seems to work well. I did as much research as I could and did not see any negative reviews. They are priced a lot less than others, which was my main reason for going with them. I figured if it turned out to be a bad choice at the very worst I would have all the ducting in place and could install another make. From what I have been able to see it is a knock off of the Webasto or Espar heater . These are basically truck heaters with a through hull fitting for exhaust. If you want what I think is the top line marine heater I have seen, go for the Wallas they are made specifically for marine use and from what I read are very quiet, not that I find the Plannar noisy . I have read as others have mentioned not to run these heaters on low all the time to avoid carbon build up. With that in mind do not get too big of a heater for your boat or it wont be working hard enough. I looked very hard at a hydronic system that would heat the water in the cooling system of the boat. This would give you hot water for showers as it heats as a side benefit, but requires more draw on the 12 volt system as you are running a pump, a heater fan and a fan in the furnace, so I went with an air heater. Most of the tugs that have a diesel heater have no generator so the heater is installed where the generator would go. The unit is the size of a loaf of bread so although not huge needs some room. I climbed into the starboard storage area with the heater and a light, closed the hatch and found the best spot I could to make everything work the best with the least amount of fittings . I will post some pictures later to assist anyone wanting to dive into this project. Is not complicated just takes some time, and basic skills.
"If you want what I think is the top line marine heater I have seen, go for the Wallas they are made specifically for marine use and from what I read are very quiet"
I agree the Wallas is much quieter and my experience with the wall as is that it is well made. If I ever have to replace my Wabasto I would definitely go with the Wallas.
As far as getting a heater too big, this is true. If it is too big you will always run it on low. I feel mine is too large, but I keep it on high to prevent the carbon build up and just leave a couple of windows cracked open. This is probably safer anyway in case of carbon monoxide.
