Dinette Light
Karll
R-29 Classic
TBD
SEAduced
My dinette light stopped working. Checked both the on/off switch on DC panel and the dimmer switch at the light. Doesn’t make sense that all 3 lights would go out at once. Looked at the fuse panel but can’t make any sense out of it. Any suggestions.
You say you checked the dimmer switch, but just to make sure, did you try both rotating it and pressing it? Press it while turned fully one way, then fully the other just to make sure.
Just a thought: the nut holding the switch/dimmer in the base can come loose, at least on the unit in our R-31. So at that point I could turn the dimmer knob, but nothing happened. Once I tightened the nut it worked fine again.
