DBBRanger
- Mar 31, 2013
- R-25 Classic
- Still Crazy
The table in my R25 tends to move a bit as others have noted even though mine has two legs to support it. I didn't want to deal with putting blocks on the wall for support because I didn't want through bolts in the cabin wall nor did I want to add additional legs for support. So I made a structure that bolts to the seat edge and screws into the bottom of the table. Those bolts and screws make it such that I only needed it on one side - it keeps the table from moving up or down. I made it out of oak and used some fairly heavy-duty screws to hold it together. The through bolt goes into the cave and has a nut and washer on it. The whole thing works very nicely to stabilize the table. It is important to note though that we never lower the table to make a bunk. This solution would not be convenient if we did.
