Discoloration in the cockpit sink
Normf943
R-21 EC
FMLC2837D919
Grey Goose
Any suggestions on cleaning this sink. The discoloration does not appear to be corrosion. So am not sure what caused it.
Hi there,
Without seeing it first hand, I can't say for sure what you're experiencing. Regardless, I would recommend trying a little scouring powder with some Scotch Brite (green) and see if that works.
If the stain is organic, you'll be able to tell by applying a small amount of bleach to the affected area and letting it sit for a few minutes. If it starts to dissipate, you can be pretty sure that it was organic. You can then remove it with a few more applications. Hope this helps get you started.
Cheers,
Ralf
