trailertrawlerkismet
- Feb 23, 2011
- C-24 C
- (2022) Kismet
On the way from Roche Harbor to Anacortes my Garmin GPS showed I had 35 gallons of fuel. I've always added whatever number of gallons into the Garmin when I fueled up and I was certain I had 35 gallons when I left Roche Harbor. About 4 miles out of Cap Sante I slowed down to a slow pace and at 2 miles out, showing 25 gallons on the Garmin display the engine alarm went off and the engine quit running. My first thought was impeller but I had water discharge upon restart. Engine problem but the engine compartment was dry and the oil level proper. The engine did restart but the engine was only able to operate at idle. I continued into the marina, prepared the lines and fenders and once inside the harbor went directly to the first open slip. As I approached the slip the engine died again, all the while the engine alarm continued to blare....no overheating either. Long story short when Andrew suggested I check the Yanmar display, which I never have done, the fuel level showed zero!!!! Moral of the story is the Yanmar display is accurate and should be consulted. This story could have had a completely different end result, I got lucky but want others to learn from my embarrassing situation.
Jim F
Jim F
