rheimb1
- Sep 12, 2014
- R-25 SC
- Ruby Rose
My wife and I bought Ruby Rose “R25SC” last fall and used it as much as possible this past winter. These boats are nice as you all know. I also know that we all love our boats and give them a lot of TLC. As I sift through the chat forums of my interests I have come across two things in which everyone seems to have problems. The first one is dock rub. After only 5 months our boat has shown signs of rub. After a lot of thinking I came up with the idea of Paint Protection Film, made by 3M. This film is the stuff they put the front of your car, anywhere from the hood to behind the mud flaps to prevent rock chips. For about fifty bucks at Amazon I purchased enough for four fenders at 12” wide.
The application learning curve was fairly easy if you follow the directions to the last period. My biggest concern was, I’m I going to see it? Yes, if you look for it and yes if you don’t clean the wax off around the edges. And that is if you’re looking for it and are within 15” of the boat. See photos. gallery2.php?g2_itemId=39972
The other issue has to do with patio rails. There is a lot of discussion about whether or not to even have one on the swim deck. I chose to put one on and user “ozoner” claimed that every boat that has them said, “I have rarely seen a swim step with rails mounted that did not have gelcoat stress cracks around where the rails mount to the swim step.” And I believe he is right. So again I got to thinking, “I don’t want that to happen on my boat!” Again I don’t know if I have the right solution, but I decided to put stainless steel plates under the swim deck rather than just using the flat washers that came with the rail. There’s not a lot of room before you get into the curve of the deck so I made that one about ½” wider than the top plate. The plate by the swim step I had to take back to the fabricator and have him cut about a ¼” off one side. Cost $130. Give me some time and I'll let you know of these ideas work.
