drop fins and new paint - 2 knots faster and less fuel
Cutwater28GG
seattle
Cutwater 28
Living The Dream
Ok im a convert.
just put the boat back in the water after trim tab repairs, upgrades with dropfins and new bottom paint. Im 2 knots faster and burning less fuel.
Im still confirming the numbers but just did a 3 hour run across various currents and typically I would have been at 3030RPM at 17.5 -18 knots. Now Im cruising at 2970 RPM and getting 19.5 to 20knts. my fuel economy at cruise has risen from 1.7 to 2.1 NMPG! Thats a huge difference!
I saw 24 knots at 3350RPM and didnt even go to full power!
Thanks for the update! Sounds very promising.
I’m looking forward to testing my adjusted trim tabs and new drop fins this week! Just getting the bow down with less trim tabs deployed will be a victory for me.
Good to hear you had a positive result. I was amazed at the benefit when I first installed the drop fins on my boat.
I'm planning to install the drop fins as well and am curious how people are aligning them, ie with the trim tab edges or the water flow. Based on the measurements from Brian's install in a prior chain, to align with water flow, it looks like for the port side trim tab, aligning the outside trailing edge 1 5/8" in, with the leading edge aligned to the edge of the trim tab, and then for the inside leading edge aligned 1 5/8" in, and the trailing edge aligned with the trim tab edge. Then opposite for the starboard side. I'm not sure if some of the benefit is lost though by having some of the surface of the trim tab outside the drop fins, such that the net result would be better if they are aligned to the trim tab edges. What is people's experience/advice on this?
I had the same concern about the drop fins not aligned with the full span of the trim tabs if the drop fins were mounted parallel to the keel and water flow. So I asked Bennett in November that specific question.
Here’s the email I received on 11/6/20 from M.J.Thomas in reply. The emphasis in caps is his, not mine. He starts speaking about the spacers to lower the tail of the trim tabs with a special order (part number A1124) Bennett designed spacer I used then talks about how to mount the drop fins. I did it exactly as he recommended on Our Journey.
“ You can SPECIAL ORDER (read as NON-STOCK item, MANUFACTURED WHEN ORDERED ONLY) them from any of your local marine dealers, catalog &/or Internet retailers – area marine distributor. Please use our “WHERE TO BUY” webpage (https://bennetttrimtabs.com/find-a-dealer/) to locate someone in your area that will be able to help you with your Special Order (we are NOT setup for direct sales of our products).
There should NOT be any type of downsides for this installation, since your trim tabs are mounted a bit too high from the start.
You can NOT use a SPACER BELOW THE LOWER HINGE of the actuator, since this will lift the LEVERAGE CONTACT POINT higher on the RIVETED/RIGHT ANGLE on the trim tab. This position will damage the RIVETED/RIGHT ANGLE & ACTUATOR over time with the chance of TRIM TAB LOSS in the future.
YES, the DROP FINS MUST BE IN LINE WITH THE WATER FLOW to work as designed. If not, they will act like “rudders” and cause undue STRESS/DRAG on the trim tabs & vessel to the point of TRIM TAB LOSS & ACTUATOR DAMAGE.”
How much down trim are you guys running at cruise? Are you maxing it out or just bringing the bow down? Do the drop fins give you more trim or just... more efficient somehow?
Both of these statement are conflicting with the information that I received from Bennett. I installed drop fins on my C26 6 months after purchasing the boat in 2016 for a couple reasons. The bow rode to high when I had passengers in the cockpit and I did not get enough response from the trim tabs to assist in bringing the bow down. The trim tabs were mounted to high on the transom and there was a loss of travel depth because of this.
I spoke with Oliver at Bennett, a veteran customer service rep that said the tab size (C26 and C28) 12X12 are to small for that boat. He was very knowledgable about the drop fins because of work he had done with Bayliner back in the late 80"s. Bayliner too rode high and Bennett made drop fin trim tabs known now has Bayliner trim tabs. Olivers advise to me was install the drop fins. I explained the angle of the transom to him. He said on a boat that has a WOT of 20Kts the efficiency loss of having the drop fins run at the angle of the transom will not be NOTICED. If the boat WOT was 30+Kts you may see a slight difference in performance. If it is 40 Kts you want them to be run-in straight (parallel ) with the keel. Olivers other suggestion was to install a spacer between the mounting surface of the Plane and the mounting surface of the hinge bracket at the base of the trim ram. This will extend the ram travel and eliminate the need to lower on the transom or install a spacer at the transom. "This as worked for years and we have had no issues with this spacer being used in this location"
I took his advise and installed the drop fins at an angle and installed the spacers. I used the trim tabs in this configuration for a season and found a significant change in the bow attitude. I was able to bring the bow down and found the boats handling and performance to be enhanced.
main.php
I'm not sure what the MJ Thomas is talking about. The integrity of the mounting location is not compromised and the load is the same why would this Cause a failure? I installed this when the boat had 120 hrs on it. It now has 650 hrs on it. I have used the boat in the open waters of Lake Michigan, the Gulf of Mexico, and many bays with choppy conditions. I use the trim tabs at full extension anytime the boat is operated above 2250 which is more than 50% of the time. I see no issues with the integrity of the install. It is a five minute install. There is nothing wrong with the transom mounted plate just a lot of extra work. It is usually used by manufactures when building the boat because of transom angles or mounting location the ram.
Having the drop fins run parallel with the boat? I did make a set of custom drop fins that would run parallel with the keel. I did not want to use the original ones because the configuration would take away from my plane surface. I made new one that would outside the running surface of the 12X12 planes. This increased the planes surface area and increasing the effects of the trim tabs. The benefits of having them run parallel were not noticed has far has change in handling or performance. The only thing I noticed was the wake was cleaner. That was it!
My advise from my experience try to get the Bennett drop fins to run close to parallel to the keel without absorbing the plane surface. It will not make a difference in performance or handling on a inboard diesel Ranger or Cutwater. I have seen many installed and talked to many that have installed them running off center to the keel and say it handles fine.The benefits of installing them will be good. I operated the boat both ways and found the efforts were not warranted.
My final trim Tab modification was to install larger planes. The only reason I did this was to eliminate the chance of damage to my Trim tabs when I am having the boat lifted out of the water with a fork truck. The only benefit of the 18 X12 larger tab on my C26 or a C28 is you do not have to worry about the drop fin getting hit by a fork. The 18 X12 plane is equal to the 12X12 with a drop fin.
I highly recommend the installation of dry fins on the Fluid motion boats by design they ride bow high stern heavy. The same way the Bayliner did.
18 X 12 trim tab
main.php
This is the link to the photos of my drop fin modifications it should answer some of your questions. More trim better efficiency at any speed above hull speed.
gallery2.php?g2_itemId=48595
I saw the same results, almost exactly. Best $32 I've ever spent (on my boat). We run with them all the way down almost all the time. The farther down the tabs, the faster the boat travels. I am getting 2nm/gal over the entire range of planning conditions.
Brian,
Yeah, not sure how much confidence I have in Bennett when two different folks give out two different and conflicting responses.
What B.J. Thomas was referring to regarding the spacers was not to put them between the BOTTOM of the actuator and the trim tab. Your install was to put your custom spacer BEHIND the actuator. Your install looked great to me, I just decided it was easier to buy their spacer than fabricate a set myself.
The Bennett spacers are cheap in price but have a long lead time.
Boat goes in the water in just a few hours and should have experience with our new trim tab configuration tomorrow.
Upgrading to the 18x12 tabs on my C28 was also one of the best investments I've made. I went that route rather than drop fins because I was replacing a broken 12x12 anyway, so I just went bigger. Did the Bennett auto trim system and indicators at the same time. Money well spent, for sure.
Hi James - did you also install the fins aligned to the tab edges? thx
