When trouble shooting water flow issue the first inspection. ( Does the installation match the Manufactures requirements? ) Of all the installs in Rangers and Cutwaters that I have looked at Dometic or Webasto the pump is mounted higher than the water line and the water fall from pump to thru hull has (peaks and valleys) The water flow from the pump to unit and unit to thru hull discharge has many peaks and valleys. The water flow piping should be installed so water flow highest point is the thru hull discharge and the lowest point the thru hull intake. If installed this way per manufactures requirements, priming and frequent flushing is not required because the system will self drain and sea critters don't live in the system. A occasional muriatic flushing or barnacle buster solution may be necessary to remove mineral deposits.
Summary of the seawater system installation:
1. Install the speed scoop thru-hull inlet as close to the keel and as far below the water line as possible, facing forward. Bed the scoop with a marine sealant designed for underwater use.
2. Install a bronze, full flow seacock on the speed scoop thru-hull inlet.
3. Install a seawater strainer below the level of the pump with access to filter.
4. Mount the pump above the strainer and at least 1’ (305mm) below the waterline.
5. Connect the seacock and strainer with an uphill run of 5/8" reinforced marine grade hose.
6. Connect the discharge from the pump uphill to the bottom inlet of the air conditioning unit's condenser coil with
5/8" hose. Connect the discharge from the condenser coil to the overboard discharge thru-hull fitting with 5/8"
hose.
7. Avoid loops, high spots or the use of 90° elbows with seawater hose (each 90° elbow is equivalent to 2.5'
(762mm) of hose and a 90° elbow on the pump outlet is equivalent to 20' (6.1m) of hose).
8. Double clamp all hose connections with stainless steel clamps, reversing the clamps.
9. Use thread sealer on all threaded connections.
10. Connect all metallic parts in contact with seawater to the vessel's bonding system including the speed
scoop inlet, strainer, pump and the air conditioner. Failure to do so will void warranty.
E1 is a water flow issue for sure. If you find that the system installation is done correctly and the pump is not pumping water you may have a bad pump. If you prime the system and the pump still is not pumping you may have a bad pump. If the system lost prime and the installation is incorrect pump above the water line. You must prime the system. There are two solutions to eliminate this issue (1) install the system to manufacturer requirements or(2) install a self priming pump. If you are having issues with marine growth fouling the system clean up the install by getting rid of all the peaks and valleys in the piping run (Hose run).
