E21 bilge pump
Slip Away
C-24 C SE
FMLT2106F213
Slip Away
Recently my bulge pump began on-off every few seconds. There was only about 1/2 “ of water. I sucked that out with turkey baster problem resolved but today with even less water it buzzes constantly . If I turn on manual it doesyresolve problem . Again sucked the water out to resolve. What’s up? Maybe some debris?
That should read turning on manual does not resolve
Pop it out and clean the impeller on the bottom of the cartridge. Should be done as a routine check.
Hello,
It sounds like your float switch is faulty, best way to test is to clean the float switch with a towel then test the float by placing two fingers on the circles that are located on the face of the float. If you have any questions feel free to email me for a quicker response.
Thank you,
Kevin Lamont
