tom boughner
- Jan 26, 2015
- C-288 C
- FMLT2903F516
- Maggie Mae
I am seeing three electrical problems, all new in the last month. I'm wondering if there could be a common cause.
1. The autopilot is not receiving GPS input. Functions that use the GPS, such as following a route, are not available. I can only use Heading Hold or pattern stearling features that do not use the GPS.
2. The aft bilge pump level switch is not functioning. The manual switch at the helm works normally to lower level.
3. There appears to be a ground loop in the circuit for the cockpit lighting. The lights turn on normally, but the courteosy lights in the cockpit are on dimly when the switch is off.
Any troubleshooting tips would be greatly appreciated. Thanks.
