dialtone
- Jul 3, 2014
- C-24 C
- Non-Fluid Motion Model
- CW30 Sedan
While connected to shore power, running the inverter (shore/charger mode), and using the coffee machine (while many other breakers were ON) white electrical smelling smoke started to come out of where my remote generator/inverter/air conditioner switches are located. I promptly killed the inverter and turned everything off.
I then proceeded to remove panels and I think I found where the issue is occurring but I'm not sure why.
Check out my pics here: http://www.screencast.com/t/96wI3ANwKV2c
1) Where my finger is pointing - I think this is the mouse fur that started to melt?? Maybe due to heat. What do you think?
2) You'll notice one of the electrical lines has a open cut in it (I'm assuming from rigging). How do you recommend I repair and could this have caused some sort of short/heat?
Thank you for the advice in advance. Normally I would post this in the cutwater forum but I was hoping to get some advice so I can put things back together this afternoon.
