Rocky Lou
- Aug 2, 2019
- C-302 C
- Sea Suite
Recently, I made two trips salmon fishing that ended in the dreaded 'skunk'. Of course, there are a myriad of factors in play including luck. However, I'm trying to eliminate any variables that are within my control. The same boat fished well last season and not much has changed except that I leave two of the refrigerators on all the time. Anodes are in good shape and downriver cable is one year old.
What is widely accepted is that positive voltage on your downrigger cable can have a major influence on fishing results. As a boat sits in the water, very small electrical currents are generated as the minerals in the water react with the different metals on the boat. If the boat is outfitted correctly, a very slight positive electrical charge will surround the hull. Fish are attracted to this positive charge. If the boat is set up wrong, an incorrect charge surrounds the hull and fish will be repelled.
I'll be checking the voltage on my cable after, first moving out of the harbor away from other sources of electrolysis, then shutting off all electronics. I'll then turn on various devices, that I normally keep running while fishing, to see if any electrical spikes occur.
I am wondering if others have done similar checks to insure their boats are 'fishy' and what were the results.
