mlanger
- May 12, 2022
- Malaga, WA
- Website
- www.mygreatloopadventure.com
- R-29 CB
- Do It Now
It seems that every time I leave the boat in the hands of someone else, something gets screwed up. This time it’s the engine battery fuse block.
I left the boat to go home and fetch my trailer for the long haul home. I was gone a little over a week. The yard I’m using to haul the boat out was told to perform a number of engine maintenance tasks. When I got back, I found the engine lid open about 4 inches, the hatch switch dead, and the engine battery voltmeter reading zero. I later traced this in the wiring diagram (page 30 in the R-29 manual) and realized that all three items on the engine battery fuse block – voltmeter, engine hatch switch, and stove switch – were dead.
The engine battery is turned on. The fuses are good. Turning on parallel power does not resolve the problem. Plugging the boat into shore power does not resolve the problem.
The mechanic claims he didn’t disconnect anything. He also claims that the engine lid switch was dead when he arrived. (No, I was not informed then, which was several days ago.) I find this extremely unlikely since I open the engine lid every cruising morning to check the situation in the bilge, the oil level, and the condition of the sea strainer. I had opened it the morning before I left. I have never had a problem with power to the engine lid cover.
I have to think that this is a simple problem with a simple solution. Has anyone experienced this and can shed some light on it for me?
I want to add here that I keep my boat in near pristine condition, fixing every problem I find as I find it. The boat is at a maintenance yard. If I had a problem, I would’ve added it to the list of items to be addressed while I was gone. I’m seriously pissed off that I was not told about this problem when it was discovered. But that’s something to gripe about to them, not you folks.
Thanks in advance for any help you can provide.
